JAWA BABETTA 207 spark plug??
I just picked up a mid 70s 207 babetta!! Still do not have it running.waiting for parts.new gas tank and carb on it's way.but does anyone know the correct spark plug to run in this bike???
Re: JAWA BABETTA 207 spark plug??
I usually run an NGK B7HS or an NGK B6HS. For some reason I seem to get better performance with the B6HS.
Vlado vlado /
see manual at
www.jawamoped.com
Congratulations! What carb did you go with? Are you converting to dellorto?
Fuck Brezhnev; Ride Jawa!
Brian Newmark /
I believe it is! I went on jawaparts .com and there was the original for $58 and the aftermarket for $39.i went with the aftermarket.i want to get it up and running then clean everything up.i know it needs a front brake but I think it's just the cable.should be a nice project for the winter.hey what ratio gas mix would you recommend to run in that bike?
