Re: strange bronzing/wear patterns on piston
Probably Fred /
You could be jetted very high and still seize because unchecked timing is what makes the temperature go high.
You need to be at the timing shown on graph at your rpm or you will have unsustaining head/combustion temps and boom
Do not run your engine even after rebuild unless you time it correctly and run a head temp gauge.
  strange bronzing/wear patterns on pistonTopic by: viv v viv v 08/25/16 12:17AM
  Re: strange bronzing/wear patterns on pistonRe: Probably Fred Probably Fred 08/25/16 12:24AM
  Re: strange bronzing/wear patterns on pistonRe: viv v viv v 08/25/16 12:34AM
  Re: strange bronzing/wear patterns on pistonRe: Daniel '' Daniel '' 08/25/16 12:40AM
  Re: strange bronzing/wear patterns on pistonRe: viv v viv v 08/25/16 12:47AM
  Re: strange bronzing/wear patterns on pistonRe: Probably Fred Probably Fred 08/25/16 02:57PM
  Re: strange bronzing/wear patterns on pistonRe: Ryan . Ryan . 08/25/16 03:49PM
  Re: strange bronzing/wear patterns on pistonRe: Probably Fred Probably Fred 08/25/16 11:29PM
  Re: strange bronzing/wear patterns on pistonRe: Ryan . Ryan . 08/25/16 03:47PM
  Re: strange bronzing/wear patterns on pistonRe: BryAn eurism BryAn eurism 08/25/16 09:29PM
  Re: strange bronzing/wear patterns on pistonRe: Marc Friedman Marc Friedman 08/25/16 11:30PM
  Re: strange bronzing/wear patterns on pistonRe: Glenn Kuehn Glenn Kuehn 08/26/16 02:43PM
  Re: strange bronzing/wear patterns on pistonRe: Daniel '' Daniel '' 08/27/16 02:33AM
  Re: strange bronzing/wear patterns on pistonRe: Saabsonettguy . Saabsonettguy . 08/26/16 09:36AM
  Re: strange bronzing/wear patterns on pistonRe: Marc Friedman Marc Friedman 08/26/16 10:32AM
  Re: strange bronzing/wear patterns on pistonRe: Probably Fred Probably Fred 08/26/16 10:54AM
  Re: strange bronzing/wear patterns on pistonRe: niklaus _ niklaus _ 08/26/16 03:48PM
