moped is dying out
it will ride for a bit, then after running at WOT it will shortly die out. it will usually turn back on fairly quickly afterwards. I was told condensor but does anyone else have any ideas?
Re: moped is dying out
Starving for gas,probably. Check fuel flow to and THRU the carb. don-ohio (:^)
Uncle Yoseph /
should i upjet?
John Pillinger /
Try taking your fuel petcock off and cleaning it
Or try switching it to reserve, I've had that happen when I thought I had enough fuel in the tank but for some reason it wouldn't flow until I filled it up, even though the fuel line would drain quickly when disconnected from the carb.
China carb or lifan ftw!!!
