Re: Mystery voltage comes and goes at the Puch Maxi taillight.
Dan (high idle) Conway /
Jim make sure it’s a 5 watt bulb, today I accidentally stuck a 6v10w in the socket and got barely anything even at high rpms. Stuck the 5w in and glowed realllll good
> Jim Franzen Wrote:
> Hi Ken,
> Thanks for the reply.
> I am sure I have a 6-volt bulb, but I am not sure it is 5-watts. It's
> the bulb that came with the Puch to me, but it was never working. I
> think I know what you are implying, that the bulb could be so high a
> wattage that the coil can't feed it enough power.
> I have a bench top power supply, so I suppose I could feed the bulb
> 5-volts DC and look at the ammeter to determine the wattage of the bulb.
> I will check the continuity of the coil. Is the other side of the coil
> grounded?
> If the coil is bad I will order another, although I still think I could
> steel 5-watts of power from the horn circuit since it's fairly unused.
> If the coil is good I will order the correct wattage bulb (if my bench
> top supply indicates the one I have is higher wattage) and see if that
> lights up.
> You've given me some things to try. Thanks for that.
> Jim
