Re: Mystery voltage comes and goes at the Puch Maxi taillight.
Overpriced Parts /
Are you using the correct 5w 6v bulb?
The horn don't use any lighting coils it goes through the ignition/ignition coil that's why it's louder and higher sounding when going your going faster.
It's easy to check the continuity of the coil the running light coil is the smallest/thinnest wire 5w coil that has gray wire
