Re: A question about air filters
Probably Fred /
You could make any abomination you want to.
The simple $14 filter as it is jets in perfect for a clean crisp jetting throughout the range, better then no filter, all other filters like foam or different abominations don't, that's all that matters.
K&N type filters are best. Polini space filter for phbg is ok too even though it's foam because it's a thin layer and has a big surface area.
  A question about air filtersTopic by: Gary Imh Gary Imh 04/21/16 08:21PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 04/21/16 08:26PM
  Re: A question about air filtersRe: Gary Imh Gary Imh 04/21/16 09:09PM
  Re: A question about air filtersRe: Saabsonettguy . Saabsonettguy . 04/21/16 09:59PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 04/21/16 10:12PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 04/21/16 09:59PM
  Re: A question about air filtersRe: Gary Imh Gary Imh 04/21/16 11:55PM
  Re: A question about air filtersRe: Gary Imh Gary Imh 05/02/16 08:48PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/02/16 11:34PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/03/16 06:58AM
  Re: A question about air filtersRe: Probably Fred Probably Fred 04/22/16 01:54AM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 04/22/16 08:32AM
  Re: A question about air filtersRe: Gary Imh Gary Imh 04/22/16 11:07AM
  Re: A question about air filtersRe: live ɘvil live ɘvil 04/22/16 12:25PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/02/16 09:21PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/02/16 11:42PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 10:10AM
  Re: A question about air filtersRe: █▓▒░ ░▒▓█ █▓▒░ ░▒▓█ 05/03/16 12:03PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 12:40PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/03/16 12:57PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 02:40PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 12:54PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/03/16 01:32PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/03/16 03:44PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 02:06PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/03/16 04:27PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/04/16 07:12AM
  Re: A question about air filtersRe: Grande Guru Grande Guru 05/04/16 11:14AM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/05/16 01:27AM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/05/16 02:22AM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/05/16 10:41AM
  Re: A question about air filtersRe: Glenn Kuehn Glenn Kuehn 05/05/16 04:26AM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/05/16 10:57AM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/05/16 08:27PM
  Re: A question about air filtersRe: Double Trouble Dan Double Trouble Dan 05/05/16 09:26PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/05/16 10:57PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/06/16 08:04PM
  Re: A question about air filtersRe: █▓▒░ ░▒▓█ █▓▒░ ░▒▓█ 05/07/16 11:54AM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/06/16 08:23PM
  Re: A question about air filtersRe: Andrew Squiggman Andrew Squiggman 05/06/16 08:25PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/06/16 09:40PM
