Re: A question about air filters
Probably Fred /
Hole is not centered making turbulence on magnum air box and small surface area of filter plus being longer the metal mesh filter makes for less performance.
2t engines can benefit from filters with good surface area and being close to carb inlet. Basically a velocity stack on end of carb is best and airbox is worse so there is even better filter for a Bing then the cheep 14$ hi flow filter.
Now a SHA no needle carb on some bikes needs restriction for low end power and nothin is written in stone with kits/Reed kits, I'm just talking about stockish puch Bing setups.
  A question about air filtersTopic by: Gary Imh Gary Imh 04/21/16 08:21PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 04/21/16 08:26PM
  Re: A question about air filtersRe: Gary Imh Gary Imh 04/21/16 09:09PM
  Re: A question about air filtersRe: Saabsonettguy . Saabsonettguy . 04/21/16 09:59PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 04/21/16 10:12PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 04/21/16 09:59PM
  Re: A question about air filtersRe: Gary Imh Gary Imh 04/21/16 11:55PM
  Re: A question about air filtersRe: Gary Imh Gary Imh 05/02/16 08:48PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/02/16 11:34PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/03/16 06:58AM
  Re: A question about air filtersRe: Probably Fred Probably Fred 04/22/16 01:54AM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 04/22/16 08:32AM
  Re: A question about air filtersRe: Gary Imh Gary Imh 04/22/16 11:07AM
  Re: A question about air filtersRe: live ɘvil live ɘvil 04/22/16 12:25PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/02/16 09:21PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/02/16 11:42PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 10:10AM
  Re: A question about air filtersRe: █▓▒░ ░▒▓█ █▓▒░ ░▒▓█ 05/03/16 12:03PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 12:40PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/03/16 12:57PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 02:40PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 12:54PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/03/16 01:32PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/03/16 03:44PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 02:06PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/03/16 04:27PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/04/16 07:12AM
  Re: A question about air filtersRe: Grande Guru Grande Guru 05/04/16 11:14AM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/05/16 01:27AM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/05/16 02:22AM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/05/16 10:41AM
  Re: A question about air filtersRe: Glenn Kuehn Glenn Kuehn 05/05/16 04:26AM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/05/16 10:57AM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/05/16 08:27PM
  Re: A question about air filtersRe: Double Trouble Dan Double Trouble Dan 05/05/16 09:26PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/05/16 10:57PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/06/16 08:04PM
  Re: A question about air filtersRe: █▓▒░ ░▒▓█ █▓▒░ ░▒▓█ 05/07/16 11:54AM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/06/16 08:23PM
  Re: A question about air filtersRe: Andrew Squiggman Andrew Squiggman 05/06/16 08:25PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/06/16 09:40PM
