Re: A question about air filters
Probably Fred /
Timing before jetting.
If timed correctly 14-18 degrees before top dead center (BTDC) with good point gap (16-18 thousand of inch) http://www.mopedarmy.com/wiki/Puch_timing
And thick head gasket removed (1.5hp has thick gasket) and thin one installed,
About 56 to low 60s range for 212A atomizer and higher 60s to 70s range if 222 Atomizer.
You may have restricted 1.5hp exhaust or blocked exhaust that will need to be addressed too.
A added 5/16 in hole to both parts of pipe helps too.
Best is a aftermarket expansion chamber exhaust for most power but magnum cylinder are angle port so maxi pipes like circuit, Proma an Estroil won't fit with out mods and the pipes made for magnums are expensive.
I've cut off my stock header on my magnum II and used this cheep pipe, 60 jet, 212A atomizer and got to 40mph
http://www.treatland.tv/exhaust-chamber-p/chamber-black-28mm.htm
It looked good too
  A question about air filtersTopic by: Gary Imh Gary Imh 04/21/16 08:21PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 04/21/16 08:26PM
  Re: A question about air filtersRe: Gary Imh Gary Imh 04/21/16 09:09PM
  Re: A question about air filtersRe: Saabsonettguy . Saabsonettguy . 04/21/16 09:59PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 04/21/16 10:12PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 04/21/16 09:59PM
  Re: A question about air filtersRe: Gary Imh Gary Imh 04/21/16 11:55PM
  Re: A question about air filtersRe: Gary Imh Gary Imh 05/02/16 08:48PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/02/16 11:34PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/03/16 06:58AM
  Re: A question about air filtersRe: Probably Fred Probably Fred 04/22/16 01:54AM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 04/22/16 08:32AM
  Re: A question about air filtersRe: Gary Imh Gary Imh 04/22/16 11:07AM
  Re: A question about air filtersRe: live ɘvil live ɘvil 04/22/16 12:25PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/02/16 09:21PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/02/16 11:42PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 10:10AM
  Re: A question about air filtersRe: █▓▒░ ░▒▓█ █▓▒░ ░▒▓█ 05/03/16 12:03PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 12:40PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/03/16 12:57PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 02:40PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 12:54PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/03/16 01:32PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/03/16 03:44PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 02:06PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/03/16 04:27PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/04/16 07:12AM
  Re: A question about air filtersRe: Grande Guru Grande Guru 05/04/16 11:14AM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/05/16 01:27AM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/05/16 02:22AM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/05/16 10:41AM
  Re: A question about air filtersRe: Glenn Kuehn Glenn Kuehn 05/05/16 04:26AM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/05/16 10:57AM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/05/16 08:27PM
  Re: A question about air filtersRe: Double Trouble Dan Double Trouble Dan 05/05/16 09:26PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/05/16 10:57PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/06/16 08:04PM
  Re: A question about air filtersRe: █▓▒░ ░▒▓█ █▓▒░ ░▒▓█ 05/07/16 11:54AM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/06/16 08:23PM
  Re: A question about air filtersRe: Andrew Squiggman Andrew Squiggman 05/06/16 08:25PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/06/16 09:40PM
