A question about air filters
Gary Imh /
My Magnum has this pipe attached to the carb:
The metal mesh filter is in the middle.
Looking at pictures of other Magnums, I'm seeing many have this type of air filter attached rather than the pipe.
What is the difference between the pipe I have and the small filter and which is better?
I'm still trying to determine cause of low power when accelerating and wondering if this pipe may be the problem. When giving it throttle, if I put my hand over part of the hole at end of pipe, the power seems to pick up.
Should I ditch the pipe and buy a small filter? Or maybe there is supposed to be something in that hole on end of pipe that I'm missing?
Thanks.
  A question about air filtersTopic by: Gary Imh Gary Imh 04/21/16 08:21PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 04/21/16 08:26PM
  Re: A question about air filtersRe: Gary Imh Gary Imh 04/21/16 09:09PM
  Re: A question about air filtersRe: Saabsonettguy . Saabsonettguy . 04/21/16 09:59PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 04/21/16 10:12PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 04/21/16 09:59PM
  Re: A question about air filtersRe: Gary Imh Gary Imh 04/21/16 11:55PM
  Re: A question about air filtersRe: Gary Imh Gary Imh 05/02/16 08:48PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/02/16 11:34PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/03/16 06:58AM
  Re: A question about air filtersRe: Probably Fred Probably Fred 04/22/16 01:54AM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 04/22/16 08:32AM
  Re: A question about air filtersRe: Gary Imh Gary Imh 04/22/16 11:07AM
  Re: A question about air filtersRe: live ɘvil live ɘvil 04/22/16 12:25PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/02/16 09:21PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/02/16 11:42PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 10:10AM
  Re: A question about air filtersRe: █▓▒░ ░▒▓█ █▓▒░ ░▒▓█ 05/03/16 12:03PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 12:40PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/03/16 12:57PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 02:40PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 12:54PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/03/16 01:32PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/03/16 03:44PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/03/16 02:06PM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/03/16 04:27PM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/04/16 07:12AM
  Re: A question about air filtersRe: Grande Guru Grande Guru 05/04/16 11:14AM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/05/16 01:27AM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/05/16 02:22AM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/05/16 10:41AM
  Re: A question about air filtersRe: Glenn Kuehn Glenn Kuehn 05/05/16 04:26AM
  Re: A question about air filtersRe: Bad Cadillac™ Bad Cadillac™ 05/05/16 10:57AM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/05/16 08:27PM
  Re: A question about air filtersRe: Double Trouble Dan Double Trouble Dan 05/05/16 09:26PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/05/16 10:57PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/06/16 08:04PM
  Re: A question about air filtersRe: █▓▒░ ░▒▓█ █▓▒░ ░▒▓█ 05/07/16 11:54AM
  Re: A question about air filtersRe: Probably Fred Probably Fred 05/06/16 08:23PM
  Re: A question about air filtersRe: Andrew Squiggman Andrew Squiggman 05/06/16 08:25PM
  Re: A question about air filtersRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/06/16 09:40PM
