Tomos pistons, carb?
Elliot Maldonado /
I have a tomos 855 70 cc jetted with a mikuni carb. Right now my kick start is getting stuck and its licking fuel, might have a piston stuck. Also not sure what my needle position should be or jet size help!
Re: Tomos pistons, carb?
Did u just put this setup on, or was it okay before? This would isolate the problem to the kick starting machanism or the piston itself. Also make sure you've a 70cc head to accompany it and a b7 or 8hs plug to go with it.
Make sure it didn't hydro lock on you.Fix the carb leak or float leak. don-ohio (:^)
Elliot Maldonado /
Thanks for the tips!
if your piston is stuck, your flywheel should be stuck. determine if it is the piston/crank or transmission.
