DIY - Puch Dial Indicator Part#278
illenium Juergen /
This tutorial is for the tool geeks like me. If I can get the original tool for a job
for an affordable price I'll get it. If not, well, time to think and make it.
The tool we'll make here is a copy of the Puch Dial Indicator, Puch Part# 278.
Total costs to build this will be in around 20$, but you will have parts to spare.
'''Lets get started shall we?'''
Hold off grasshopper, lets talk first why there is no JB Weld or similar mentioned
here...well...we moped people love to save money and this method means you
can still use your precious dial for other things.
Now....lets get started, for real.
'''Supplies'''
1 Dial Indicator, Harbor Freight, with coupon 12-14$ (1 In. Travel Machinist's Dial Indicator, Item#623)
1 Spark plug, this one was 2.38$ at Advance Auto (Its an NGK BKR5E I had left over from a car)
1 O-Ring Assortment, Harbor Freight, 5$, pick what you like
"Tools"
-Shades...yes, nothing like porcelain in your eyes, put on your shades and look smooth while staying safe
-Dremel with a cutting disc and sanding sleeve (or other cutting tool, hacksaw works but put in some sweat)
-Drill
-Vise (makes it easier, but you can do without)
-Hammer (big or small, doesnt matter)
-Something to knock out the ceramic, like a 1/4 wrench extension, an old bolt, ...
'''Step 1'''
Put on your shades, pull out your plug, put it in the vise (or hold it if you dare). Make sure
if you put it in your vice you don't damage the threads. I leave the carton around it for
that purpose.
Now using your dremel with a cutting disc cut around the sparkplug where the porcelain ends, there
is a little lip that holds it in. Its thin metal, it wont take long. Cut around the whole plug.
'''Step 2'''
Now cut off the ground electrode. That was easy, wasn't it?
'''Step 3'''
Hammer Time!! Clamp the plug upside down into your vise. Center your extension/bolt/nail/whatever
on the electrode and give it a couple gentle tabs. It wont take much, the whole porcelain and electrode
will come out in one piece. If you hulk out here you will learn why you are wearing glasses. Be gentle.
'''Step 4'''
Back on the dremel, use the sanding sleeve to smooth out any jagged edges
you might have on the plug. We want nothing pitting the cylinder.
'''Step 5'''
Now we drill a small hole at the end of the threaded portion (up, where it doesnt
make contact with your cylinder) to avoid having compression interfere with
our funky fresh tool. Make sure there are no shavings/jagged edges after
you drill.
'''Step 6'''
Take your dial indicator, fit it with three snug o-rings and insert it into the
plug base. There will be enough friction to hold your dial in place and to
gently screw the assembly into your cylinder.
'''Congratulations Grasshopper...you got yourself a sweet tool for TDC and Timing'''
Now add an ohmmeter and you are total puch-ed out for timing :)
Ride on!!(edited)
  DIY - Puch Dial Indicator Part#278Topic by: illenium Juergen illenium Juergen 03/17/16 08:38PM
  Re: DIY - Puch Dial Indicator Part#278Re: Andrew Squiggman Andrew Squiggman 03/17/16 08:54PM
  Re: DIY - Puch Dial Indicator Part#278Re: live ɘvil live ɘvil 03/18/16 12:23PM
  Re: DIY - Puch Dial Indicator Part#278Re: Dave Gjessing Dave Gjessing 03/18/16 01:58PM
  Re: DIY - Puch Dial Indicator Part#278Re: Andrew Squiggman Andrew Squiggman 03/18/16 08:54PM
  Re: DIY - Puch Dial Indicator Part#278Re: Wild West Pony Wild West Pony 03/18/16 07:07PM
  Re: DIY - Puch Dial Indicator Part#278Re: live ɘvil live ɘvil 03/18/16 07:10PM
  Re: DIY - Puch Dial Indicator Part#278Re: illenium Juergen illenium Juergen 03/18/16 07:19PM
  Re: DIY - Puch Dial Indicator Part#278Re: Ike Pipe Ike Pipe 03/18/16 09:46PM
  Re: DIY - Puch Dial Indicator Part#278Re: illenium Juergen illenium Juergen 03/22/16 02:44PM
  Re: DIY - Puch Dial Indicator Part#278Re: Wild West Pony Wild West Pony 03/22/16 12:51PM
  Re: DIY - Puch Dial Indicator Part#278Re: live ɘvil live ɘvil 03/22/16 01:16PM
  Re: DIY - Puch Dial Indicator Part#278Re: Wild West Pony Wild West Pony 03/22/16 02:33PM
  Re: DIY - Puch Dial Indicator Part#278Re: Wild West Pony Wild West Pony 03/22/16 03:32PM
  Re: DIY - Puch Dial Indicator Part#278Re: illenium Juergen illenium Juergen 03/22/16 07:36PM
  Re: DIY - Puch Dial Indicator Part#278Re: Wild West Pony Wild West Pony 03/23/16 01:18PM
  Re: DIY - Puch Dial Indicator Part#278Re: ♣Slew Foot♣ ♣Slew Foot♣ 03/24/16 06:26PM
  Re: DIY - Puch Dial Indicator Part#278Re: EH FCC of the QCB EH FCC of the QCB 03/24/16 10:35PM
