Moped no longer starting
Gary Imh /
I had my Magnum running, although rough as it had a few air leaks at both ends of the intake. I put some O-rings over top where the intake goes into the carb and that fixed that leak (it was running smoother). I then changed the intake gasket (for a second time, as that gasket was fairly new) and now moped will not start at all. Today I put in a new spark plug just to be sure, and I've re-seated the intake gasket a few times as well. I pulled out the main jet, blew some carb cleaner into the needle jet as well as cleaned the float bowl. Float pin is new and float seems to be working fine.
I don't have a compression tester but when I pull the plug, put my hand there and give the pedals a crank, I am feeling pressure.
Points have been cleaned but I haven't set the timing.
What should I be looking at next? It's driving me a bit crazy that I finally got it running and am now back to square one..
Thanks
  Moped no longer startingTopic by: Gary Imh Gary Imh 03/09/16 08:47PM
  Re: Moped no longer startingRe: Gary Imh Gary Imh 03/09/16 08:49PM
  Re: Moped no longer startingRe: Probably Fred Probably Fred 03/09/16 09:11PM
  Re: Moped no longer startingRe: Gary Imh Gary Imh 03/09/16 09:34PM
  Re: Moped no longer startingRe: Probably Fred Probably Fred 03/09/16 09:47PM
  Re: Moped no longer startingRe: Gary Imh Gary Imh 03/25/16 06:58PM
  Re: Moped no longer startingRe: Probably Fred Probably Fred 03/25/16 07:09PM
  Re: Moped no longer startingRe: Gary Imh Gary Imh 03/25/16 07:18PM
  Re: Moped no longer startingRe: Mikey q Mikey q 03/25/16 08:53PM
  Re: Moped no longer startingRe: Jesus G. saldivar Jesus G. saldivar 03/29/16 12:14AM
  Re: Moped no longer startingRe: ♣Slew Foot♣ ♣Slew Foot♣ 03/30/16 03:02PM
  Re: Moped no longer startingRe: Gary Imh Gary Imh 03/30/16 03:15PM
  Re: Moped no longer startingRe: Wild West Pony Wild West Pony 03/30/16 05:19PM
  Re: Moped no longer startingRe: Gary Imh Gary Imh 03/30/16 05:53PM
  Re: Moped no longer startingRe: Gary Imh Gary Imh 04/13/16 12:18PM
  Re: Moped no longer startingRe: Jack Rutherford Jack Rutherford 04/13/16 01:28PM
  Re: Moped no longer startingRe: Don Ohio Don Ohio 04/13/16 02:43PM
  Re: Moped no longer startingRe: Gary Imh Gary Imh 04/13/16 02:47PM
  Re: Moped no longer startingRe: Pizza the Hutt Pizza the Hutt 04/13/16 07:46PM
  Re: Moped no longer startingRe: Gary Imh Gary Imh 04/13/16 08:36PM
  Re: Moped no longer startingRe: Pizza the Hutt Pizza the Hutt 04/15/16 08:28AM
  Re: Moped no longer startingRe: Gary Imh Gary Imh 04/15/16 08:39AM
  Re: Moped no longer startingRe: Pizza the Hutt Pizza the Hutt 04/15/16 10:35AM
  Re: Moped no longer startingRe: Gary Imh Gary Imh 04/15/16 01:04PM
  Re: Moped no longer startingRe: Gary Imh Gary Imh 04/15/16 08:12PM
  Re: Moped no longer startingRe: Gary Imh Gary Imh 04/18/16 09:39PM
