Re: Minarelli V1 External Condenser Wiring
Pops Peds /
That plugs to your extrrnal coil,not the one behind the flywheel..just unplug the wire to the coil and plug the spade to the coil then plug the blade in to the wire your unplugged at the coil ..make sure to ground the condensor on a screw or bolt
