Re: Removing the "brass tube" - Dellorto SHA
Ike Pipe /
> Dylan Wallis Wrote:
> I just did this! I didn't have the 2/56 bolt or tap, but I did have a
> 2mm bolt that was fairly long. I just tightened the bolt into the brass
> tube. Then I used a heat gun and warmed up the entire carb, the tube
> pulled out smoothly.
Proud of you. 😘
  Removing the "brass tube" - Dellorto SHATopic by: Dave Gjessing Dave Gjessing 03/07/16 02:45PM
  Re: Removing the "brass tube" - Dellorto SHARe: Bad Cadillacâ„¢ Bad Cadillacâ„¢ 03/07/16 03:20PM
  Re: Removing the "brass tube" - Dellorto SHARe: Don Ohio Don Ohio 03/07/16 05:12PM
  Re: Removing the "brass tube" - Dellorto SHARe: Dave Gjessing Dave Gjessing 03/07/16 05:26PM
  Re: Removing the "brass tube" - Dellorto SHARe: Dave Gjessing Dave Gjessing 03/07/16 06:48PM
  Re: Removing the "brass tube" - Dellorto SHARe: Kevin Bishop Kevin Bishop 03/07/16 09:59PM
  Re: Removing the "brass tube" - Dellorto SHARe: Ninja . Ninja . 03/18/16 10:49PM
  Re: Removing the "brass tube" - Dellorto SHARe: Ike Pipe Ike Pipe 03/18/16 11:51PM
  Re: Removing the "brass tube" - Dellorto SHARe: Ike Pipe Ike Pipe 10/09/16 08:12PM
  Re: Removing the "brass tube" - Dellorto SHARe: cheetahchrome . cheetahchrome . 10/09/16 08:55PM
  Re: Removing the "brass tube" - Dellorto SHARe: Marc Friedman Marc Friedman 10/09/16 11:41PM
  Re: Removing the "brass tube" - Dellorto SHARe: Jimmy Cauchon Jimmy Cauchon 10/10/16 12:43PM
  Re: Removing the "brass tube" - Dellorto SHARe: Dave Gjessing Dave Gjessing 10/10/16 01:58PM
  Re: Removing the "brass tube" - Dellorto SHARe: Ike Pipe Ike Pipe 10/27/16 09:28PM
  Re: Removing the "brass tube" - Dellorto SHARe: Grande Guru Grande Guru 10/28/16 06:49AM
  Re: Removing the "brass tube" - Dellorto SHARe: Frank Bailey Frank Bailey 10/28/16 09:21AM
  Re: Removing the "brass tube" - Dellorto SHARe: Ike Pipe Ike Pipe 10/28/16 07:36PM
  Re: Removing the "brass tube" - Dellorto SHARe: Ninja . Ninja . 10/29/16 05:04PM
  Re: Removing the "brass tube" - Dellorto SHARe: Ike Pipe Ike Pipe 10/29/16 06:09PM
  Re: Removing the "brass tube" - Dellorto SHARe: - Dacruzer - - Dacruzer - 10/29/16 08:28PM
  Re: Removing the "brass tube" - Dellorto SHARe: steven kline steven kline 10/31/16 04:37PM
  Re: Removing the "brass tube" - Dellorto SHARe: Ike Pipe Ike Pipe 10/31/16 06:13PM
  Re: Removing the "brass tube" - Dellorto SHARe: Dave Gjessing Dave Gjessing 10/31/16 05:41PM
  Re: Removing the "brass tube" - Dellorto SHARe: Marc Friedman Marc Friedman 10/31/16 07:09PM
  Re: Removing the "brass tube" - Dellorto SHARe: Ike Pipe Ike Pipe 10/31/16 08:34PM
  Re: Removing the "brass tube" - Dellorto SHARe: steven kline steven kline 11/03/16 12:30PM
  Re: Removing the "brass tube" - Dellorto SHARe: Marc Friedman Marc Friedman 11/03/16 01:40PM
  Re: Removing the "brass tube" - Dellorto SHARe: Ike Pipe Ike Pipe 11/03/16 07:54PM
  Re: Removing the "brass tube" - Dellorto SHARe: Dave Gjessing Dave Gjessing 11/03/16 06:10PM
  Re: Removing the "brass tube" - Dellorto SHARe: Ike Pipe Ike Pipe 11/06/16 05:12PM
  Re: Removing the "brass tube" - Dellorto SHARe: - Dacruzer - - Dacruzer - 11/06/16 05:39PM
  Re: Removing the "brass tube" - Dellorto SHARe: Ike Pipe Ike Pipe 11/06/16 06:45PM
  Re: Removing the "brass tube" - Dellorto SHARe: - Joe - - Joe - 12/09/17 08:59AM
  Re: Removing the "brass tube" - Dellorto SHARe: Ike Pipe Ike Pipe 12/18/17 11:21PM
  Re: Removing the "brass tube" - Dellorto SHARe: pat splat pat splat 12/09/17 10:52PM
  Re: Removing the "brass tube" - Dellorto SHARe: Marc Friedman Marc Friedman 12/09/17 11:13PM
  Re: Removing the "brass tube" - Dellorto SHARe: P D P D 12/09/17 11:47PM
  Re: Removing the "brass tube" - Dellorto SHARe: Dylan Wallis Dylan Wallis 08/09/20 04:31PM
  Re: Removing the "brass tube" - Dellorto SHARe: Ike Pipe Ike Pipe 08/09/20 09:42PM
