Re: Help with vespa piaggio ciao
Ninja . /
I run most of my Vepas without a headgasket, someone on the forum did a compression test and it’s a little higher compression without one.
If you intend to drop a 70cc piston into this case, you will need to bore or carve the case out to accommodate this larger piston. If you have a stock case, I’m assuming you do, the largest kit you can buy is a 64cc or a 43mm kit.
  Help with vespa piaggio ciaoTopic by: Jesus G. saldivar Jesus G. saldivar 12/07/15 12:47PM
  Re: Help with vespa piaggio ciaoRe: Ninja . Ninja . 12/07/15 06:02PM
  Re: Help with vespa piaggio ciaoRe: Richard Eberline Richard Eberline 12/07/15 07:33PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 12/07/15 10:01PM
  Re: Help with vespa piaggio ciaoRe: Ninja . Ninja . 12/07/15 11:17PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 12/08/15 11:14AM
  Re: Help with vespa piaggio ciaoRe: Ninja . Ninja . 12/08/15 11:56AM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 12/10/15 10:37PM
  Re: Help with vespa piaggio ciaoRe: cheetahchrome . cheetahchrome . 12/10/15 11:24PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 12/12/15 10:12PM
  Re: Help with vespa piaggio ciaoRe: cheetahchrome . cheetahchrome . 12/12/15 11:04PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 12/13/15 12:35PM
  Re: Help with vespa piaggio ciaoRe: cheetahchrome . cheetahchrome . 12/13/15 12:56PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 12/13/15 01:20PM
  Re: Help with vespa piaggio ciaoRe: cheetahchrome . cheetahchrome . 12/13/15 01:33PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 12/13/15 01:58PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 12/13/15 02:28PM
  Re: Help with vespa piaggio ciaoRe: cheetahchrome . cheetahchrome . 12/13/15 02:44PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 12/14/15 02:16AM
  Re: Help with vespa piaggio ciaoRe: Ike Pipe Ike Pipe 12/20/15 08:32PM
  Re: Help with vespa piaggio ciaoRe: Lou MAGNETO Lou MAGNETO 01/07/16 02:19PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 01/10/16 02:14PM
  Re: Help with vespa piaggio ciaoRe: Bad Cadillac™ Bad Cadillac™ 01/10/16 03:43PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 01/12/16 01:43AM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 01/17/16 01:51AM
  Re: Help with vespa piaggio ciaoRe: Ninja . Ninja . 01/17/16 09:39AM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 01/17/16 10:21PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 01/18/16 12:24AM
  Re: Help with vespa piaggio ciaoRe: Ninja . Ninja . 01/18/16 09:12AM
  Re: Help with vespa piaggio ciaoRe: Ike Pipe Ike Pipe 01/18/16 09:31AM
  Re: Help with vespa piaggio ciaoRe: alex . alex . 01/17/16 11:31PM
  Re: Help with vespa piaggio ciaoRe: alex . alex . 01/19/16 12:37AM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 01/19/16 02:50AM
