Re: Help with vespa piaggio ciao
Ike Pipe /
Jesus,
I've been working on my Bravo for six months with similar issues. Yesterday I swapped out the brand-new High-Tension coil for the one from another Bravo that was running perfectly, and it did the trick. If you have a multimeter, you can test your coil. The flat connector that sticks out of the side, touch it with one lead from the multimeter. Touch the other to the mount or someplace grounded. My working one read 1.1 on the 200 ohm setting. The broken one read 2.1, and the original one that I'd replaced read nothing.
The 2.1 coil was certainly creating visible spark. The problem is that when I put the plug in the cylinder, it must not have been making spark. Why? Because at one atmosphere (15 PSI) sparks jump more readily than they do at cylinder pressure (what? 120 PSI? I think I've seen people say that's what compression should be).
Anyway, an adjustable ignition tester like this one
will allow you to see how far the spark will jump while spinning the engine. The farther it jumps, the stronger your ignition. I haven't had a chance to test my good coil to see just how far it jumps, so I don't know what a good reading looks like. I do know the bad coil would jump only 3mm, which is apparently not a good number, as I could not start the bike.
  Help with vespa piaggio ciaoTopic by: Jesus G. saldivar Jesus G. saldivar 12/07/15 12:47PM
  Re: Help with vespa piaggio ciaoRe: Ninja . Ninja . 12/07/15 06:02PM
  Re: Help with vespa piaggio ciaoRe: Richard Eberline Richard Eberline 12/07/15 07:33PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 12/07/15 10:01PM
  Re: Help with vespa piaggio ciaoRe: Ninja . Ninja . 12/07/15 11:17PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 12/08/15 11:14AM
  Re: Help with vespa piaggio ciaoRe: Ninja . Ninja . 12/08/15 11:56AM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 12/10/15 10:37PM
  Re: Help with vespa piaggio ciaoRe: cheetahchrome . cheetahchrome . 12/10/15 11:24PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 12/12/15 10:12PM
  Re: Help with vespa piaggio ciaoRe: cheetahchrome . cheetahchrome . 12/12/15 11:04PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 12/13/15 12:35PM
  Re: Help with vespa piaggio ciaoRe: cheetahchrome . cheetahchrome . 12/13/15 12:56PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 12/13/15 01:20PM
  Re: Help with vespa piaggio ciaoRe: cheetahchrome . cheetahchrome . 12/13/15 01:33PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 12/13/15 01:58PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 12/13/15 02:28PM
  Re: Help with vespa piaggio ciaoRe: cheetahchrome . cheetahchrome . 12/13/15 02:44PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 12/14/15 02:16AM
  Re: Help with vespa piaggio ciaoRe: Ike Pipe Ike Pipe 12/20/15 08:32PM
  Re: Help with vespa piaggio ciaoRe: Lou MAGNETO Lou MAGNETO 01/07/16 02:19PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 01/10/16 02:14PM
  Re: Help with vespa piaggio ciaoRe: Bad Cadillac™ Bad Cadillac™ 01/10/16 03:43PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 01/12/16 01:43AM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 01/17/16 01:51AM
  Re: Help with vespa piaggio ciaoRe: Ninja . Ninja . 01/17/16 09:39AM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 01/17/16 10:21PM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 01/18/16 12:24AM
  Re: Help with vespa piaggio ciaoRe: Ninja . Ninja . 01/18/16 09:12AM
  Re: Help with vespa piaggio ciaoRe: Ike Pipe Ike Pipe 01/18/16 09:31AM
  Re: Help with vespa piaggio ciaoRe: alex . alex . 01/17/16 11:31PM
  Re: Help with vespa piaggio ciaoRe: alex . alex . 01/19/16 12:37AM
  Re: Help with vespa piaggio ciaoRe: Jesus G. saldivar Jesus G. saldivar 01/19/16 02:50AM
