QT50 No Spark
Running through a bunch of issues and trying to get my QT50 started and running.
I tried to start it today and checked my plug and I'm getting no spark. Brand new plug, brand new ignition coil. I was getting a spark when I got the QT50 two weeks ago.
What should I check for with a multimeter on the rectifier and CDI module? I did notice my CDI module has blue goo dripping off of it - like melted plastic almost.
Getting really frustrated chasing issues around on this thing but I think I'm close!
Re: QT50 No Spark
are you sure you have the ignition correct? did you see i replied to your earlier post?
Re: QT50 No Spark
Luke Vidacovich /
I'm sure. The brake light is coming on when I connect the battery which means it's in RUN.
Re: QT50 No Spark
79 = Charge coil.
Re: QT50 No Spark
Luke Vidacovich /
How would i check to be sure arlie?
Re: QT50 No Spark
Luke Vidacovich /
don't wanna buy a $50 part without being sure
Re: QT50 No Spark
one on the left is bad, one on right is good.
Re: QT50 No Spark
Luke Vidacovich /
Can I not test it with a multimeter?
Re: QT50 No Spark
Yes, it's in the manual. http://projectmopedmanual.info/Manual_HTML/yamaha.html Search qt50 no spark several post on this here.
Re: QT50 No Spark
Luke Vidacovich /
I did search - I'll check out the manual though.
