qt50 Bypass Ignition??
My QT50 was stolen. I got it back but they tore out the ignition switch. All there is now is a flat plate with several connecting points. Which ones do I need to connect for the ignition to be on?
Thanks.
Re: qt50 Bypass Ignition??
Is yours the OFF and RUN type or OFF START RUN?
If it's OFF RUN you just need to connect the red and brown wires.
