Transmission screw stripped
The bolt to take my clutch side cover is stripped. Nothing works to get it out the screw hole just isnt big enough and the screwdriver or drill head just strips it more. I need to take it off because my crank seal is popped out or broke. I cant get it with a dremel either.
Help please
Its a tomos targa lx (a35)
Re: Transmission screw stripped
Justin Gossett /
Cut the head off
All the transmission cover bolts are allen heads, you stripped one of those out?
Not an allen head. It is the level screw http://i.imgur.com/osHOWwo.jpg
(not my pic).
Also cant even get to the head.
The level screw has nothing to do with holding on the clutch cover.
Yeah, that screw wont stop you from removing the cover. Once the cover is off you can just drill it out and replace it.
__̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ /
use a cutting disc to make slot deeper.
