TOMOS TURN SIGNAL PROBLEMS
When I put on the turn signal all the signals flash... how could this be... it's really annoying because no one knows where I'm going... the rights will blink then the lefts right after thrn right and so on.. any tips.. anyone else have this issue....
Re: TOMOS TURN SIGNAL PROBLEMS
Moped Lar (OFMC) /
Use your hand signals and people will know where you're going.
Sometimes a bad ground will cause the power to feed back through the other side. Clean and grease all connections.
will do thanks peter
Brian Stogsdill /
Did this end up fixing your problem? I have the same issue.
