ciao cracking engine cases
I've done some searching and I can't find anything. The keywords seem too general.
I rebuilt the engine on my new ciao this week because I discovered a crack in the engine case. the next day it stopped running because of an air leak from a crack in the case.
I can figure it out myself but some ideas as to where to look would be helpful: it was along the top front engine bolt both times. Maybe the frame is too close together? Too far apart? I'm going to rule out vibration as that is barely noticeable at most rpms. I'll inspect the frame but I don't think there are any cracks.
for context, it's a small kit (maybe 65cc), stock portmatched cases, and a racing crank... New bearings and seal.
Re: ciao cracking engine cases
barney gierer /
Maybe the gasket wasnt in the corect posotion when you put the case together or the mating surfaces need cleaned
so the crack is in the same spot? Is there actually a crack or is there just an airleak?
***VANILLA BLUNDER*** /
Put some jb weld in it and rock and roll till it explodes
^^this. its just mopeds
Dirty30 Dillon /
Yeah, I'm confused as well. Is there an actual crack in the cases?
If so, new cases for sure. Or, if you're trying to diagnose why the crack happened????
I think he's trying to diagnose what could cause two sets of cases in a row to fail the same way, hoping that someone has experienced the same. For those of us that haven't, pics would help a lot, having trouble imagining where/how it cracked. (edited)
macelius, that's exactly right. Here's a picture of the crack. It's seriously tiny. I'm trying jbweld as the case half is already shot so there's nothing to lose. Tighten the engine bolts and cross fingers. I'll know tomorrow whether it holds.
Dirty30 Dillon /
To me, it looks like that is right around where the bolt for the engine mount goes through.
I'd check your frame for severe flex or even cracks. Could be the engine cases are the only think holding the frame from twisting and that's why they keep giving up the ghost
No cracks, all the welds are solid, I can't get it to flex noticeably.
barney gierer /
Maybe it happened during disassembly. Or a bad surface imperfection during assembly.
Those two bolts are def structural points for subframe. Bummer.
