Re: Weird issue with A35 clutch maybe not sure
Jason Grimm /
If the plug is completely white you may be running dangerously lean, check for air leaks asap and if you have no leaks then upjet and see if that helps. I had a stock A35 that had an air leak, it got insanely hot and started slowing down when going up hills like you are describing. It ran hot but ok on flat ground because of the wind blowing over the cooling fins, then started to overheat and run like complete shit when going up hills or cruising slowly because of the lack of wind
