Back fire through the carb?
wilfrin hiciano /
I have been riding my bike trying out new clutch settings. It seems like when I decelerate, the carb kind of spits at me through the air intake. Does that mean that my timing is off?
Re: Back fire through the carb?
NO!
wilfrin hiciano /
That helps a lot. Thanks -___-
When this happened on my Moby, it was the condenser. Timing was fine but the condenser was toast.
wilfrin hiciano /
thanks max ill look into that
All piston port motors spit gas out of the carburetor, sometimes enough to get your pants leg wet...
wilfrin hiciano /
the way it does it tho is like a pop/puff from the carb.
Sounds like misfire check points and/or ignition timing...
Probably Fred /
> leg wet...
Maybe for you but I had very few bikes do that
If low compression piston/rings on their last legs....
cool...
> leg wet...
This is semi-common for piston port engines but usually isnt that much. Sounds like its misfiring for some reason
Yeah, a decent air filter will fix that...
wilfrin hiciano /
I was thinking of that. Currently I have no air filter on it
As I posted if it's spitting gas then the filter is what you want...but if it's popping/mis-firing then check points/ign. and compression...
wilfrin hiciano /
I current don't have an air filter on my bing carb at all. Does that affect air flow at all?
Yeah, a little...but try and get the $14. metal mesh K&N style filter and be good-to-go....
