Re: Oil line came out on the ride home.. Am I doomed?
Born to be WillD /
these are the reasons people say "run premix" and "disconnect oil injector"
because there's just so many little things that could go wrong, and they're so catastrophic when they do.
Seems like you got lucky, it'll probably continue running, you could reconnect the injector or drain it and run pre-mix gas (advisable)
there will likely be less power now that you've probably scored it up a bit, lowering compression, but might still be usably OK
don't SAND anything, you can use a brake hone on the inside of the cylinder, you can sand grooves off the piston, you can cut/scrape melted metal out of the ringland too and make sure the rings seat snug but can also move/not get stuck.
getting a kit, do some research. the stockoshocko and 77 cast iron kits are more work and crappy and nearly worthless. DR is the best all around value, performance and reliability. you don't need a new carb, you definitely will want a pipe, and you DO need to upjet.
  Oil line came out on the ride home.. Am I doomed?Topic by: Matthew Hicks Matthew Hicks 12/08/14 11:29PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Probably Fred Probably Fred 12/08/14 11:38PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/08/14 11:42PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/08/14 11:43PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Chris Straub Chris Straub 12/08/14 11:48PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/08/14 11:59PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Probably Fred Probably Fred 12/08/14 11:59PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/09/14 12:12AM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Ryan . Ryan . 12/09/14 12:36AM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/09/14 12:59AM
  Re: Oil line came out on the ride home.. Am I doomed?Re: joe muncey joe muncey 12/09/14 01:06AM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/09/14 01:26AM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Chris Straub Chris Straub 12/09/14 05:25AM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Ryan . Ryan . 12/09/14 12:00PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: joe muncey joe muncey 12/09/14 02:31PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Born to be WillD Born to be WillD 12/09/14 02:56PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/09/14 03:58PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Ryan . Ryan . 12/09/14 04:05PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/09/14 04:22PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Ryan . Ryan . 12/09/14 04:35PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/10/14 02:21AM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/10/14 06:05PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Probably Fred Probably Fred 12/10/14 06:12PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Ryan . Ryan . 12/10/14 06:19PM
