Re: Oil line came out on the ride home.. Am I doomed?
Ryan . /
You have likely damaged the rings and/or cylinder in your haste to get the thing going without being sure it was roadworthy. Even if it runs, it is hurt. If you could salvage the stock cylinder a new piston will run you 50-60 dollars, but if there is scoring to the walls of the jug, a kit is going to sit you at about 150 shipped AND YOU BETTER FUCKING JET THE CARB.
  Oil line came out on the ride home.. Am I doomed?Topic by: Matthew Hicks Matthew Hicks 12/08/14 11:29PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Probably Fred Probably Fred 12/08/14 11:38PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/08/14 11:42PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/08/14 11:43PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Chris Straub Chris Straub 12/08/14 11:48PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/08/14 11:59PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Probably Fred Probably Fred 12/08/14 11:59PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/09/14 12:12AM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Ryan . Ryan . 12/09/14 12:36AM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/09/14 12:59AM
  Re: Oil line came out on the ride home.. Am I doomed?Re: joe muncey joe muncey 12/09/14 01:06AM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/09/14 01:26AM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Chris Straub Chris Straub 12/09/14 05:25AM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Ryan . Ryan . 12/09/14 12:00PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: joe muncey joe muncey 12/09/14 02:31PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Born to be WillD Born to be WillD 12/09/14 02:56PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/09/14 03:58PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Ryan . Ryan . 12/09/14 04:05PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/09/14 04:22PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Ryan . Ryan . 12/09/14 04:35PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/10/14 02:21AM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Matthew Hicks Matthew Hicks 12/10/14 06:05PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Probably Fred Probably Fred 12/10/14 06:12PM
  Re: Oil line came out on the ride home.. Am I doomed?Re: Ryan . Ryan . 12/10/14 06:19PM
