Vespa Case/Kinetic CDI Help
Nick Wesolowich /
So, if I am setting up a Ciao with Polini case and a Kinetic CDI, is there a way of modifying the standard vespa points flywheel to work with the kinetic cdi, or do I need to locate a kinetic cdi?
Re: Vespa Case/Kinetic CDI Help
Dirty30 Dillon /
You're gonna need the CDI flywheel
Nick Wesolowich /
Does the Vespa cdi flywheel work with the kinetic cdi?
I'm not sure, but I don't think so, unless the magnets are somehow in the same place, keep postin in the buy/sell.
GL
~M
Dadon Martino /
Unfortunately you can only use the Kinetic flywheel with it's ignition.
I've used a Berini ignition with this SE, after the connection to mount the pointers was broken.
You still can use the ignition coil of any vespa. (edited)
Dirty30 Dillon /
^^^ Hot damn that is pretty.
