2stroke gurus.. need help....excessive smoke
What would be your conclusion to this problem:
Oil smelling Blue smoke (cool or warm)
Top 1/3 of the piston faces are black
Spark plugs come out looking like their old diesel engines (pure black)
Leaned it out and no diffrence
Amsoil saber or Maxima K2 @ 40:1
Re: 2stroke gurus.. need help....excessive smoke
Probably Fred /
Not jetted correctly through the range making for incorrect air/fuel mix.
Rejet/retune
Roger Suarez /
Better a video!
What bike is it? In some cases it can be bad crank seals pulling oil in from the transmission. Depends on the bike though.
Roger Suarez /
Yea but ATF burns white. My Tomos knows all about that. This is baby blue smoke. ATF fluid is housed in one side of engine and it smokes even from both pipes.
How about oil blow by?
Just clean the residue out of both pipes and run 50:1 or disconnect oil injection not both on that Yamaha... it's supposed to smoke some...this is a moped site...
Except that not all bikes use ATF. One more time, what bike.
Roger Suarez /
1974 RD350
You are aware this is a moped forum right?
In any case, the RD350 uses 10W-30 in the gearbox, and could totally be the source of your smoke. Tell me some more about how your Tomos is just like a motorcycle.
Jet rattled loose.
