Tomos pedal spring
jinsin jindiffler /
After replacing the 2nd gear clutch on my 2001 tomos a35 and re-assembling to the best of my memory, the pedals would spin nearly free on reverse rotation. I now notice the pedal shaft can slide left/right to engage/disengage, so my question is, where does the spring on the pedal shaft go?
Re: Tomos pedal spring
Did you reinstall the shims on the end of the pedal shaft? The spring and the cupped washer go on the pedal shaft after you've installed the cover, and before you've installed the pedal arm.
jinsin jindiffler /
I installed one shim, how many are supposed to be there?
My grandfather Ned Nickens knows a guy Tim Yinderson who is good with tomos. He lives local to you. You should get in contact
With him
Another choice would be Skuts moped repair manual. Literally everything you could ever need is in that booklet
