Grease Maxi Swingarm Bushing?
Just what the title says. Repainted my Maxi and need to know if I should grease the rubber swingarm bushing.
A search didn't turn up anything.
Re: Grease Maxi Swingarm Bushing?
Being you have the motor off you might as well put fresh rubber in there...If it's not that old and still tight you could put a little WD-40 on it but alot of grease will turn it to mush over time...
I was surprised when I pulled the rubber out and cleaned it up. No signs of wear, and still pliable. I just wasnt sure if there was any lube involved to keep it fresh or not. Thanks!
Grease or oil and rubber are both made from petroleum and the rubber will break down if you over do it, so that's why I say a little WD...
i use sil glyde on a lot of rubber and plastic stuff.
Yup, you want silicone lubricant for rubber. Sil-Glyde is the stuff for brake caliper pins etc.
(edited)
and buttsecks
