1982 honda urban express
I have a 1982 Honda Urban Express that has a bad stator.How do you go about installing a new one?
Thanks in advance.
krate007
Re: 1982 honda urban express
fallout Survivor /
It is highly unlikely that it has a bad stator.
Bad Stator?? how so....Alternator.....
fallout Survivor /
The service manual I downloaded from the site I gave you is comprehensive and gives instructions on alternator removal.
What makes you say it has a bad stator? Try a fresh battery and do the tests in the manual.
klaus sieg /
I've tried a new battery.It just gets drained.Won't charge on the machine.Any other suggestions?
That is a bad rectifier most likely.
fallout Survivor /
Get a volt meter and teach yourself motorcycle electronics and electrical trouble shooting. See if the alternator is putting out AC voltage. If it is it could be a bad rectifier. If you had a 6 v ac source (assuming 6 v system, if 12 you need a 12 v ac source, see if the rectifier converts it to DC.)
The service manual will specify a number of other tests.
Hard to recommend a course of action because you have not explained the symptoms.
klaus sieg /
Where is the rectifier located?
In the battery box.
Downhill Harvey (OFMC) /
Have you even read the manual? under the seat, from riders right, is the 5-pin CDI, rectifier (which has cooling fins), and the flasher (which is barrel shaped). Try your local Honda dealer, they can always get the part, but it might take a couple days.
As stated previously, get the factory service manual or download it somewhere. I like to have a hard copy on hand personally. It will give numerous electrical tests that will help you troubleshoot. If you don't have one, get a multimeter from home depot or somewhere for like $20. Both the manual and the meter will pay you back 10 times over. (edited)
Only the NU50M has a regulator/recitifer with fins. All other express just gave a simple little black plastic rectifier attached to a 2 pin plug.
..............^^^ It is anNU50M,
1982 honda urban express manual
fallout Survivor /
http://projectmopedmanual.info/Manuals/Honda/Honda-NU50-shop-manual.pdf
p13-11 in the manual for tests.
I gave you a link, but you have to click on the "main page... toggle into "Honda" . Then you can view and download the NU50M manual.
Extensively illustrated.
A multimeter is a good investment, you will use for life for auto, moped, home, and even battery testing. (edited)
I never bothered to look at the picture. That the rectifier is under the seat then.
