Re: Swing arm on a dart.....
Saabsonettguy . /
As far as I know the lower portion of the frame (motor mount part) is the same as pinto/swinger/cobra/ some magnums so it'll probably take any regular puch swing-arm. I think the dart may have a standard maxi swing-arm. Remove the shocks and see if you've got side to side play in the swing arm. It rides on a rubber bushing that could be worn.
