now that I have it running good the last thing is that when running the bike keeps going the same speed when I bring the throttle to idle, it will come down to idle when I put on the brakes, the slide in the carb is going down, any ideas?
throttle hangs
Re: throttle hangs
If the slide returns to bottom of the carb bore it should make a click sound...you always want to hear that....If you still have the problem then you have an air leak...
Re: throttle hangs
yea, thats either lean or the throttle mechanically sticking, though im gonna lean towards lean
Re: throttle hangs
I messed with it today, adj. the mixture and slowed down the idle, it"s better but still does it some. I can"t find any air leaks, and the slide is going all the way down, I can hear the slide click, and can see it.
Re: throttle hangs
If u hear it click then look for an air leak, use carb cleaner with the little straw...
