vespa points arcing / condensor...what else?
Hey Moped Millitants
I've been fighting Vespa ghosts and think I finally cornered the bitch. I looked in the peep hole while engine is running and my points are doing some type of firework show(spark is visible, jumpy, and inconsistent). I can throw on a different condenser..I've got some new points laying around here too. Before I start the basics:
What's the other causes for arcing points?
Re: vespa points arcing / condensor...what else?
Dirty30 Dillon /
Usually always condenser, and it's worth putting the points outside the cover/inline so they're easier to change and don't see as much heat.
The points outside
Dirty30 Dillon /
My bad, condenser
Darrell Gabbard /
points get dirty from arching and need to be cleaned with a file and a bad spark plug/ plug wire can cause arching too. and make sure all ignition grounds are clean. plus there will always be arching at the points.
If everything ls perfect and while it's running you peek in the window...what should you see? Steady spark, no visable spark, or non rhythmic? My problem was a bad igni coil.
