Well I tried to pull my clutch with a clutch puller and the picture below is what happened. What can I do at this point? Also I'm not really trying to destroy my crackshaft any further...
Puch - Clutch puller splitting crankshaft!
Re: Puch - Clutch puller splitting crankshaft!
shit nvm I found the answer https://www.mopedarmy.com/forums/read.php?6,3716424,3716424#msg-3716424
Ya leave the nut on somewhat
That's what I was going to suggest but now he only has one choice...torch and hammer time you got nothing to loose go for it and show your skill...
Actually I was able to vice grip it 50 times to get that gap closed. Had to dremel down some of the screwed threads from the vice grips. All in all I don't think the crankshaft is destroyed.
Anyhow I have it soaking in oil since a few drops and propane torch wasn't happening. Maybe it's because this clutch has been dry for at least 5 years...
I'll report back if it being saturated in oil overnight, propane torch and retard strength don't do the trick.
You might be able to weld up the end of the crank and re-drill the hole?
A machine shop can fix it but might be cheaper to replace it, check around both ways.
damn lucky it's the KS, no starter issues.
Impressive.( in a James Earl Jones voice)
