Hey folks;
I've noticed that the PA50 feels a bit odd when ridden, so I decided to have a look at the alignment. The front half of the rear wheel was slightly to the right. The only way I could see to correct this was to push the right-hand side axle adjustment forward a bit.
So now, the wheel appears to be straight, but the hash marks on the axle adjustments no longer match on the left and right.
There's no visible bends or cracks in the subframe.
So am I stuck replacing a subframe, leaving the axle adjusted as-is, or ?
