'78 Pinto Leaking Gas
Xavier Ó Luain /
I recently purchased this little bike. It has taken a while for me to get it running just right. My spark plug finally looks healthy after adjusting idle and learning to ride it right. However, as it has gotten cooler outside and since I adjusted the throttle, gas has begun leaking out of the carb. I was told I'd need to adjust the carb as it got cooler. Any ideas?
Re: '78 Pinto Leaking Gas
take it apart and clean it, especially where the gas enters the bowl & float seat. check your gaskets if it has any also. If you still have a problem after that you may need to adjust your float.
Overpriced Parts /
http://www.mopedarmy.com/wiki/Fix_a_leaky_Bing
Searching wiki is not hard to do
Xavier Ó Luain /
Just joined this world today. Thanks for the direction!
