MUST shim your clutch bell/drum correctly like Ryan says. The clutch starter plate shouldn't ever really rattle around. if it does, it's going to wear down the slots in the clutch bell/drum and then it will get worse and worse. so shim them properly!
https://www.mopedarmy.com/forums/read.php?2,3732972,3737036#msg-3737036
