Re: Sachs starts but rear wheel wont move?
Dan Kubica /
Not the same dude, but the tapered part of the crank is kinda like the axle of your crank that tapers down or goes from a larger diameter to a smaller diameter.
http://www.mopedarmy.com/wiki/Lapping_tapered_crankshaft_and_flywheel_surfaces_for_good_no_slip_bond
See second picture. The taper part is that pole sticking out in the middle.
