Re: Seized Puch Maxi Engine (Need Advice/Thoughts)
Jonathan R /
Welcome to mopeds. You're in luck having one of the easiest transmissions to work with (the E50)!
I would try getting a socket on the flywheel nut like you're going to pull it. Sometimes it will turn over and break the piston or crank free if stuck.
