Welcome to mopeds. You're in luck having one of the easiest transmissions to work with (the E50)!
I would try getting a socket on the flywheel nut like you're going to pull it. Sometimes it will turn over and break the piston or crank free if stuck.
Subject | Written By | Posted |
Seized Puch Maxi Engine (Need Advice/Thoughts)Topic by: Maxwell Falcon | Maxwell Falcon | 09/29/14 05:13PM |
Re: Seized Puch Maxi Engine (Need Advice/Thoughts)Re: Saabsonettguy . | Saabsonettguy . | 09/29/14 05:25PM |
Re: Seized Puch Maxi Engine (Need Advice/Thoughts)Re: Maxwell Falcon | Maxwell Falcon | 09/29/14 07:05PM |
Re: Seized Puch Maxi Engine (Need Advice/Thoughts)Re: Jonathan R | Jonathan R | 09/29/14 07:11PM |
Re: Seized Puch Maxi Engine (Need Advice/Thoughts)Re: Maxwell Falcon | Maxwell Falcon | 09/29/14 08:02PM |
Re: Seized Puch Maxi Engine (Need Advice/Thoughts)Re: Maxwell Falcon | Maxwell Falcon | 09/30/14 01:12PM |
Re: Seized Puch Maxi Engine (Need Advice/Thoughts)Re: Moped Lar (OFMC) | Moped Lar (OFMC) | 09/30/14 01:17PM |
