A35 Clutch Washer That Bends
Simon Belmont /
Hey guys, I wanted to ask something, on the A35 there's a nut that holds clutches in place, the thing is even after tightening it, every-time the side cover is removed, that nut is always lose, I've seen a picture that has a washer which can be bent in order to prevent it from loosening:
Anyone knows where I could get a washer like that?
Or can I just use blue loctite instead?
Re: A35 Clutch Washer That Bends
The A3 had the tab washer, not the A35 which has a sort of internal toothed lock washer. Are you torquing the nut to factory specs? Loctite wouldn't hurt, but it shouldn't be coming loose.
Tptwo Tptwotwo /
Get an exact replacement A35 clutch washer brand new and use it .. buy several because you're supposed to put a new one on every time you take the clutch off. If you don't do that you're asking to chip the splines off your crank shaft .. you'll hear a whine instead of a nice quiet Tomos purr.
Simon Belmont /
Thank you guys for your advise, as I don't have a compatible washer on hand, I'll give blue loctite a try.
Try hardware store.
