So I have a cherry 1979 magnum mk ii.
It will not run.
So far everything looks like it's here.
So I looked for spark.
Nothing.... Peddle and the engine does not turn...... Houston we have a problem!
So I can see someone had some trouble with the cable that is on the left bar. It's frayed. So I adjusted the nut in and pulled as much as I could and tightened it. Peddle, engine does not turn.
Poped the side covers off, rotated by hand and I have compression. A bit of sludge in the red oil. But pull the lever and the engine does not turn.
What should I see when I pull the bottom left lever? Do I need to pull the clutch and transmission?
Ty in advance for your help.
