Pitted shaft
Rich Swingewood /
Hey,
What do you if your crankshaft is pitted were the seals run, machine it down and then resleeve it or try and clean it up as much as possible and hopefully it seals? To replace it is just not economical and sachs engines are like hens teeth actually any moped engine is hard to come by.
Cheers
Rich
Re: Pitted shaft
Brent Bublitz /
505 1a motors are actually really easy to come by. Have 3 in the garage now.
Re: Pitted shaft
Russell Meyers /
Get a'' speedi'' repair sleeve. Available at bearing supply stores.
Re: Pitted shaft
Post pics! chances are it's not as bad as you think it is.
Re: Pitted shaft
Rich Swingewood /
Cheers guys,
Sorry only checked the posts now,I will take some pics in the next couple days.
Over here in Australia, they are not so easy to come by, that is the whole problem. Don't really want to spend to much money it .
I did not think of just sleeving it and going up a size in a seal.
Cheers
Rich
