Morini Mo2 sarter mech.
Morini mo2. For some reasonable.I put the clutch cover on it will not engage the mechanism feels almost like it is jammed when I pull the cableor like it's hitting something. but works fine when the clutch cover is off. Any ideas on what is causing it? its baffeling me because there seems to be no reason this is catching on anything.
Re: Morini Mo2 sarter mech.
The bushing that is on the end of the crankshaft,the one the large washer and starter clutch disc slide on...does it have a groove that the large washer is settling into(the large washer actuall cuts this groove into the bushing)? That can happen and keep the bearing from being able to push the large washer against the clutch disc. don-ohio (:^)
turns our I had the big washer in the completely wrong spot. hmm. don't know how that got mixed up but now we are in tip top shape! rad! thanks don!
Yer welcome,Nathan! May all your roads be trouble-free. don-ohio (:^)
