I have used a gun to compare it to the Trail Tech gauge and get very similar readings.
There are two problems with the gun however.
First you have to move it around to get the highest temp which is what the Trail tech is reading and the correct temp.
The other issue is the fact you must be stopped and do not get a true reading of what the temps were at WOT.
