Yea I know, it's a Trac. Thanks South Korea.
It runs, barely.
With the spark plug out and resting on the head, if you turn the motor over slowly with the pedals, it doesn't get spark. If you crank it HARD, the spark comes to life. I can get it to run by stomping on the pedal REALLY hard. The battery is there and hooked up, but it's not in the best condition. Once it runs, all the lights work properly.
Now on to the running issue... it will run on starting fluid and die out once it eats that all up. I pulled the carb apart and it was spotless, but the fuel lines were all shitty and there was old gas in the tank. Not sure if something got back in the carb after I cleaned it, replaced one fuel line, and put new gas in.
I had it running enough to ride around the block but then it died out, and I need it running. I will replace the fuel lines and clean the tank out again, and maybe pull the carb apart again, but I am not sure what's going on with the spark issue.
Any insight?
