Re: a35 oil plug issues
kyle routhier /
Hi everyone problem solved, I ended up winging it before I could see post replies, also with help from my group Psyclomoteur Montreal. I ended up removing cover , luckily noticed washers stuck to the inside cover. Bored hole to 11/32 and tapped 3/8. Used brass bolt and hacksawed the length . Used a perfect fitting tiny o ring as washer.
