Re: a35 oil plug issues
Simon Belmont /
When removing the cover, if the existing gasket isn't ripped, I just used "permashield fuel resistant gasket dressing" and applied thin layer of it onto existing gasket, also if you stripped the hole where the drain bolt goes, not to worry, just buy "tap and hex die set" at your local hardware store to make a new hole and buy a matching bolt size for the hole that you've made (make sure you re-thread a hole that is similar to the one you had before as close as possible).
P.S. I've used Tap and Hex Die set to re-thread the studs that hold cylinder head on an A35 engine and it worked, purchased "Dewalt" set at home-depot. (edited)
