Problem Starting JcPenney Pinto
Finally got my first Moped! It was a barn find and therefore needs a little lovin. I can't seem to start it.
I've checked the spark - spark seems to be good
Cleaned out the carburetor - pretty clean not much gunk there
It seems that the clutch isn't catching. But since this is my first moped, I'm not sure what it's supposed to feel like. When I pull the clutch, I can easily push the bike and it doesn't seem like the engine is turning over. I already checked the transmission fluid and the level was okay. Is it possible that the clutch is too worn out? (According to the Odometer, it only has 900 miles)
Are there any other things I should be checking?
Thanks!
J
Re: Problem Starting JcPenney Pinto
Fuck your Boys Club /
Check the cable tension on the clutch lever. It might not be pulling the arm enough. It shouldn't be an easy peasy pull, it should have a bit of hulk to it.
If that doesn't help I would dig into the clutch side and make sure everything is properly shimmed and the clutch pads aren't toast.
can you turn the flywheel, is the motor free?
Brent Bublitz /
Your cable is not pulling hard enough. Adjust your cable.
Adjust that cable or manually push the lever forward and then try to start it.
Princess Rapunzel /
Wait - if you can't turn it over, how'd you check for spark?
Hi Jess,
I'm in Annapolis, over the past 3-4 yrs, I've gotten pretty good with Puchs (thanks to the MA gang here). I also have tools and love to tinker with them. If you need some help PM me.
