Re: Problem Starting JcPenney Pinto
Fuck your Boys Club /
Check the cable tension on the clutch lever. It might not be pulling the arm enough. It shouldn't be an easy peasy pull, it should have a bit of hulk to it.
If that doesn't help I would dig into the clutch side and make sure everything is properly shimmed and the clutch pads aren't toast.
